Tech.Git History
Hide minor edits - Show changes to output
Changed lines 162-170 from:
(:sourceend:)
to:
(:sourceend:)
'''Remove the last commit from Git history'''
(:source lang=bash :)
git reset --hard HEAD~1
(:sourceend:)
If the commit has already been pushed to the remote, and you want to propagate the change (WARNING: this is bad if someone already has the commit that will be deleted into his history):
git push -f
(:sourceend:)
(:sourceend:)
git push -f
(:sourceend:)
Changed lines 146-159 from:
It will create a new commit. The reverted commit is still present in the history.
to:
!! How to rewrite history
The git rebase command allows you to easily change a series of commits, modifying the history of your repository. You can reorder, edit, or squash commits together.
'''Warning''': Because changing your commit history can make things difficult for everyone else using the repository, it's considered bad practice to rebase commits when you've already pushed to a repository.
'''Rebase all the commits between another branch and the current branch state'''
git rebase --interactive other_branch_name
(:sourceend:)
'''Rebasing commits against a point in time'''
To rebase the last few commits in your current branch, you can enter the following command in your shell:
git rebase --interactive HEAD~7
(:sourceend:)
(:sourceend:)
(:sourceend:)
Changed line 120 from:
To remove a remote branch
to:
To remove a remote branch or tag
Changed line 124 from:
To remove a remote tag
to:
To remove a local tag
Deleted line 126:
Changed line 122 from:
git push origin :branch_to_delete
to:
git push origin --delete branch_or_tag_to_delete
Added lines 32-38:
(:sourceend:)
!! Work on a remote branch
git fetch origin
git checkout -b mybranch origin/mybranch
git fetch origin
Deleted line 97:
Added line 101:
Note: It is better to don't use an already existing tag name to name your branch.
Changed line 5 from:
Some other [[http://mislav.uniqpath.com/2010/07/git-tips/ git tips]]
to:
Some other [[http://mislav.uniqpath.com/2010/07/git-tips/|git tips]]
Added lines 4-5:
Added lines 120-131:
!!How to synchronize a branch with the remore repository?
If the branch has no upstream:
git pull origin v1.4-maintenance
(:sourceend:)
The best option is to provide the -u option when pushing to the remote to specify the upstream automatically.
To easily track a remote branch from someone else
git checkout -t origin/feature
(:sourceend:)
It creates and checks out "feature" branch that tracks "origin/feature".
(:sourceend:)
(:sourceend:)
Changed line 95 from:
!! How to push a new branch to the remote
to:
!! How to push a new branch to the remote?
Changed lines 100-101 from:
!! How to delete a remote branch/tag
to:
!! How to create a tag?
It will create an annotated tag (recommended)
git tag -a v1.4 -m 'my version 1.4'
(:sourceend:)
To list tags:
git tag
git tag -l v1.4/*
(:sourceend:)
!! How to delete a remote branch/tag?
(:sourceend:)
To list tags:
git tag
git tag -l v1.4/*
(:sourceend:)
to:
Added lines 104-108:
(:sourceend:)
git tag -d tagtodelete
git push origin :refs/tags/tagtodelete
!! Push a new branch to the remote
to:
Changed line 100 from:
!! Delete a remote branch
to:
Added lines 95-105:
git push origin newbranch
(:sourceend:)
(:sourceend:)
Changed lines 94-101 from:
You can also check this [[http://mislav.uniqpath.com/2013/02/merge-vs-rebase/|useful post]]
to:
!! How to revert a commit?
It is as simple as
git revert 5f1b62549477
(:sourceend:)
It is as simple as
(:sourceend:)
Added lines 30-46:
(:sourceend:)
!! Remove untracked files
git clean -f
(:sourceend:)
If you want to also remove directories, run
git clean -f -d
(:sourceend:)
If you just want to remove ignored files, run
git clean -f -X
(:sourceend:)
If you want to remove ignored as well as non-ignored files, run
git clean -f -x
git clean -f
(:sourceend:)
git clean -f -d
(:sourceend:)
git clean -f -X
(:sourceend:)
git clean -f -x
Deleted line 13:
Deleted line 22:
Deleted line 26:
Changed line 64 from:
# %item value=3% Then, Compare any branch from your local repository to any remote you've added.
to:
# %item value=3% Then, compare any branch from your local repository to any remote you've added.
Added lines 4-33:
!! Git info
There is no git info (like svn info) command available with git :(
Instead you can use following commands.
!!! List remote URL
git remote -v
(:sourceend:)
!!! List branches
Remote branches:
git branch -r
(:sourceend:)
Local branches:
git branch
(:sourceend:)
!!! Git configuration
cat .git/config
(:sourceend:)
!!! Most recent commit
git —no-pager log —max-count=1
(:sourceend:)
Added lines 25-39:
(:sourceend:)
!! How to diff between a fork with its origin repository?
# First, in your forked repository, add the origin as a remote
git remote add <aname-refering-to-the-origin-repo> <origin-git-url>
(:sourceend:)
# %item value=2% Fetch origin changes into your forked repository. It won't change your working copy.
git fetch <aname-refering-to-the-origin-repo>
(:sourceend:)
git diff master <aname-refering-to-the-origin-repo>/master
(:sourceend:)
(:sourceend:)
Changed lines 28-29 from:
If you are many people working on the same software, your central git repository will end with a lot of branches and merge. Indeed, developers start to work on a revision and, when they are ready to push their changes, there will probably be new revisions from other developers. The default behavior of git when pushing your changes is to define a branch, add your commits to this branch and then merge the branch back to the master. To avoid that, especially if you know there is no conflict, you can use %black%git rebase%%.
See[[http://git-scm.com/book/en/Git-Branching-Rebasing|Git rebasing]] ([[http://alx.github.io/gitbook/4_recombinaison_(rebase).html|french]]).
See
to:
If you are many people working on the same software, your central git repository will end with a lot of branches and merge. Indeed, developers start to work on a revision and, when they are ready to push their changes, there will probably be new revisions from other developers. The default behavior of git when pulling changes from the central repository is to define a branch, add your commits to this branch and then merge the branch back to the master. To avoid that, especially if you know there is no conflict, you can use %black%git rebase%% as explained [[http://git-scm.com/book/en/Git-Branching-Rebasing|here]] or [[http://alx.github.io/gitbook/4_recombinaison_(rebase).html|here (french)]].
Hopefully, there is a shorcut for that. You can use pull with %black%git pull --rebase%%. Git can be configured to make it the default behavior:
git config --global --bool pull.rebase true
(:sourceend:)
(:sourceend:)
Changed line 27 from:
!! How to avoid many branches in your repository
to:
!! How to avoid many branches in your repository?
Changed line 29 from:
See [[http://git-scm.com/book/en/Git-Branching-Rebasing|Git rebasing]] ( [[http://alx.github.io/gitbook/4_recombinaison_(rebase).html|french]]).
to:
See [[http://git-scm.com/book/en/Git-Branching-Rebasing|Git rebasing]] ([[http://alx.github.io/gitbook/4_recombinaison_(rebase).html|french]]).
See [[http://git-scm.com/book/en/Git-Branching-Rebasing|Git rebasing]] (or [[http://alx.github.io/gitbook/4_recombinaison_(rebase).html|(french)]]).
to:
Changed lines 25-29 from:
(:sourceend:)
to:
(:sourceend:)
Added lines 2-3:
The Git community book [[http://alx.github.io/gitbook/index.html|(french)]] [[http://git-scm.com/book|(english)]]
Changed lines 1-2 from:
!Git How-tos
to:
!%center% Git How-tos
Changed line 23 from:
(:sourceend:)
to:
(:sourceend:)
Changed line 10 from:
# Then, fetch origin changes into your forked repository
to:
# %item value=2% Then, fetch origin changes into your forked repository
Changed line 14 from:
# List branches to see new available branches from the origin repository
to:
# %item value=3% List branches to see new available branches from the origin repository
Changed line 18 from:
# Now, we can merge
to:
# %item value=4% Now, we can merge
Added lines 1-21:
!! How to synchronize a fork with its origin repository?
MyA is a fork of the repository A.
You use MyA for your devs and made updates. In the same time, the origin repository A still follows its way (new push, etc.).
How to do if you want to (re)synchronize your forked repository with its origin?
(:sourceend:)
(:sourceend:)
git branch -a
(:sourceend:)
# Now, we can merge
git merge remotes/<aname-refering-to-the-origin-repo>/<branch-name>
(:sourceend:)
(:sourceend:)
(:sourceend:)
git branch -a
(:sourceend:)
# Now, we can merge
(:sourceend:)
